09-10-2020 08:32 PM - edited 01-05-2022 01:10 PM
Why does the PM SIM not have the APN settings built in?
Other than going the APK route or ordering a Freedom Mobile SIM, is there any other way to get the APN settings into Android 8.1?
09-10-2020 10:55 PM
@KMD77 wrote:Why does the PM SIM not have the APN settings built in?
APN settings are never saved on any sim card. It's up to the phone manufactuer to pogram them into the software, or for the user to manually do that if necessary.
09-10-2020 10:53 PM
To submit a ticket to the Moderator Team, please start a conversation with the Public's virtual assistant, SIMon by clicking here or the icon (bottom right of your screen).
If you are still having problems contacting Public Mobile then click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
09-10-2020 10:40 PM
how do I submit a ticket to PM?
09-10-2020 08:54 PM - edited 09-10-2020 08:55 PM
@KMD77 Your only other option is to submit a ticket to PM explain that you are unable to add or edit any APN settings on your device and ask them to send you a text that will add the correct APN settings to your device.
Good luck, hope this helps!
