05-22-2019 04:54 PM - edited 01-05-2022 05:02 AM
05-22-2019 08:28 PM
Nope still the same
05-22-2019 07:50 PM
@kiranmuddinedi wrote:I do have limited minutes but, my plan started on 20 may and i have minutes left in my plan.
@kiranmuddinedi When making a call try dialing the number directly do not use your contacts to make a call and see if it works.
05-22-2019 06:00 PM
Have you set up your Access Point Name (APN) on the phone? That was the problem we had with our first phone. Went without data for a month until we did a bit of googling.
for an Android phone, it is:
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN type: Leave blank Select Save/Done. Select Public Mobile to connect to the Public Mobile network
05-22-2019 05:51 PM
@kiranmuddinedi wrote:I did send a message to moderator, but haven't heard back and clicked on lost/stolen phone in my account profile. But still the same.
**bleep** it's so irritating
One other thing to try while you're waiting for the moderators to respond is try to top up your account with one or two dollars and restart the phone...this sometimes helps to reset the account too.
05-22-2019 05:47 PM
@kiranmuddinedi wrote:Thanks much for your help
@kiranmuddinedi Sometimes a plan has provisioning problems and needs to be fixed by the @CS_Agent hang tight they should respond soon.![]()
05-22-2019 05:43 PM
05-22-2019 05:35 PM
yes i did
05-22-2019 05:34 PM
@kiranmuddinedi Unfortunately you will need to wait for the moderator to respond. When your tried the Lost/Found trick did you restart your phone?
05-22-2019 05:27 PM
05-22-2019 05:17 PM
@kiranmuddinedi wrote:still the same
@kiranmuddinediTry the lost/stolen phone trick sometimes it works like a soft account reset.
To report your phone stolen. Login to your selfserve account. Choose Plans and Add-ons tab. Choose the Lost/Stolen Phone tab. Choose Suspend Service tab. Wait a few minutes. Report your phone found. Re-start you phone.
If that doesn't work then you need to notify PM. To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderator Hours: Monday-Friday 8 am(Eastern) to 12 am (Eastern) and Saturday, and Sunday from 8 am(Eastern) to 10 pm (Eastern).
05-22-2019 05:13 PM
still the same
05-22-2019 05:11 PM
@kiranmuddinedi The fact that you can dial *611 signifies that you are connected to public mobile. If your account is active and you have verified that you have available minutes are you dialing one specific number? Can you try calling another number? Since May 20th have you been able to make a call?
05-22-2019 05:09 PM
I'm on 15$ plan and i have full 100 minutes left in my plan
05-22-2019 05:04 PM
05-22-2019 05:03 PM - edited 05-22-2019 05:04 PM
@kiranmuddinedi wrote:Its saying i dont have a active plan, but when i log into my account it's showing as active
@kiranmuddinedi Are you on the $10 or $15 plan? If yes, when you login does it show available minutes on the first page? If not, then maybe you don't have anymore minutes?
05-22-2019 05:01 PM
Yes, my account is active and in good standing
05-22-2019 05:00 PM
05-22-2019 05:00 PM
Does your plan have a limit on minutes?
Try your sim in a different phone but do check online to ensure your account is in good standing.
Good luck!
05-22-2019 04:59 PM
No idea, how to fix this issue.
05-22-2019 04:59 PM - edited 05-22-2019 05:00 PM
@kiranmuddinedi wrote:its connecting to automated system
@kiranmuddinediOK good, so what happens when you try to dial a number? Are you on a unlimited calling plan?
05-22-2019 04:58 PM
05-22-2019 04:55 PM
@kiranmuddinedi wrote:Hi all,
i Have active plan but cannot make calls. How to solve this issue ?
@kiranmuddinedi What happens when you make a call do you get a message? If you call *611 do you get a response back?
05-22-2019 04:55 PM
I restarted my phone, took sim out, but still the same
