01-21-2023 03:18 PM
I was in the middle of activating and something whent wrong but money was taken out and card is not working
Service
01-21-2023 05:59 PM
@TinaCooper Did you at least get in touch with support ?
01-21-2023 03:34 PM
@softech None taken was just explaining to @TinaCooper @how and we’ll rest you can both read lol
01-21-2023 03:32 PM - edited 01-21-2023 03:33 PM
- @TinaCooperfirst off you can edit your excepted solution under your name on post to the right by time stamp edit it and remove excepted solution , and did you port and use imei as @softech suggested if so it’s time to get support
01-21-2023 03:31 PM
@TinaCooper oh, I thought you had the solution, you can go back to the post you picked and select "Not the solution" (no offend @Handy1 )
for your issue, can you tell me if you gone thought the end of the activation step?
anyway, open ticket with Pm support as what I suggested above and wait for support to reply. They will reply within 2 hours
01-21-2023 03:28 PM
No solution yet
01-21-2023 03:21 PM - edited 01-21-2023 03:38 PM
@TinaCooper Did you reboot phone try taking SIM card out and another device and or take it out and reseat it in sim tray and make sure tray is pushed all the way in .. otherwise if it’s a provisioning issue you need supports help
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here
- you can send a private message to our CS_Agents by clicking here.
01-21-2023 03:20 PM
@TinaCooper did you got an error like error 821 or 835? were you requesting porting and used IMEI number?
anyway, open ticket with PM support via direct message to get it sorted out first
