Activation
Ugh2
A new subscription was set up and payment went through. On step 6 the activation failed. How do I resolve this?
Ugh2
Three days later and my issue has been resolved. Thanks to all of you for your replies and help and all of the customer care agents help.
Try the new sim card first
And support usually need a bit of time to reply, 1 or 2 hours.  check Community inbox
Ugh2
I sent in a ticket.  Still waiting
Ugh2
I never made it to the part of replacing the sim card. It failed right at that point.
porcupine
Contact and agent to help you resolve your issue did you reply yes when you received your text messages and then you replaced your sim card
Chalupa_Batman
If you're having issues with activation, you need to use the app to finish it off. Once you've used the app to finish it off, your account should be active. If it's not working for you, you can create a ticket.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
