Activation of phone
09-01-2021 08:51 PM - edited 01-06-2022 03:20 AM
09-01-2021 10:49 PM
@APigeon123 wrote:We haven't received an activation code yet for my phone
If you just ported your phone number from another cell provider it could take a few hours to complete the port.
Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
Make sure you do not cancel your previous provider's services.
Incoming calls are usually the last to port over.
See helpful info. here: https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
Leave the OLD provider SIM card in your phone to accept the PORT via SMS/text.
If you missed this 90 minute window, submit a ticket via this link to re-initiate the port:
Link to contact Customer Support Agents (CSA) for porting to Public Mobile
09-01-2021 08:53 PM - edited 09-01-2021 08:55 PM
@APigeon123 What activation code?
are you existing user trying to do a SIM Swap and waiting for a 2FA code?
or you are new user for new activation? For new activation, you can use 2GBBonus as the promo code for plan $35 and above. You can also put in a Friend Referral code you got from your friend
