Activation issue
06-08-2019 06:12 PM - edited 01-05-2022 05:17 AM
Hi there,
I'm trying to activate a new SIM card for Public Mobile. I used to be on Public Mobile, ported my number out to Fongo (as I was out of the country for the year), and now am trying to activate a new SIM card.
I got to the payment screen and put in the credit card and tried to activate. I got back a response that said that the activation failed and to contact support.
Any help?
Thanks!
Joining Public
06-08-2019 06:26 PM
You may also want to check your credit card to make sure that you were not billed for the activation. Chrome incognito seems to work well for most people.
You might also want to activate a new PM number first. Make sure that it is working before porting your number back from Fongo.com.
If all fails, you will need to contact moderator, but expect 1-2 day wait.
Send a private message to moderator through the following link :
06-08-2019 06:21 PM
@obixlink and try with a different browser or on incognito mode..it could help.
06-08-2019 06:19 PM - edited 06-08-2019 06:20 PM
@obixlink wrote:Hi there,
Any help?
Thanks!
Edit: Did it give a specific message?
Try in another hour but use a different email address from what you used here before.
