Activation failed
RaedS
I was in the last steps to activate my new account but failed. What should I do now?
2 REPLIES 2
rai79
Are you stuck on Step 6 of the activation?
HI @RaedS
try reboot the phone and login to app again and see if you can complete the subscription
and if you are activating eSIM, can you double check if the PM  eSIM is already showing up on your Sim Manager or Settings-> Ceulluar?
if yes, then you need to manually enable it
if not, ask PM support agent to help, you can submit  ticket by direct message:
