Activation code? How do I get it
08-26-2022
07:40 PM
08-27-2022
01:13 AM
computergeek541
08-27-2022 01:15 AM
True, while CS agent likely will tell customer the same answer, I guess we can help a bit to deliver the message. Also, it saves customer time to wait for an answer that we could all helped
08-27-2022 01:02 AM - edited 08-27-2022 01:13 AM
@Timer wrote:but Public Mobile does not currently support eSIM. but as you say it's SIM card the
contact support team by private message CS_Agent
There isn't any reason to contact a Public Mobile CSA. Public Mobile can't help with this.
As was previously pointed out, you appear to be in the eSIM activation settings. Public Mobile does not allow use of eSIMs.
08-26-2022 09:03 PM - edited 08-26-2022 09:03 PM
@minxynossboss wrote:I’m using the actual SIM card and when I go
to network it says iPhone not aloud
Did you activate the Public Mobile SIM card? If yes, simply inserting in and rebooting your iPhone should work. If not, check what phone do you have. If it's older than 2020, see if it's locked to any carrier. If locked, you need to contact that carrier to get it unlocked.
08-26-2022 08:34 PM
I don't think you need support. You just need to not use the esim option. You don't add plans for this service. Activate the sim through the Public activation method using the link up top and then insert it. You might need to select the actual using of the sim rather than the esim.
08-26-2022 07:52 PM - edited 08-26-2022 07:59 PM
08-26-2022 07:50 PM
08-26-2022 07:48 PM
Hi @minxynossboss ,
are you trying to activate via eSIM? we don't use that here
Please use physical sim card. Get one from Telus or Koodo store
08-26-2022 07:45 PM
contact from where you getting your device brand or carrier the frist time you activated with to give the code, for free.
