11-11-2022 02:07 PM
I am newcomer and buy a public mobile Sim card at a shop. They gave me a sim card and a 40$ pin code to add fund to my account. I want to activate my Sim card but I cannot pay the plan price by this code. I do not have credit or debit card yet. How can I activate my Sim and use the pin code?
11-11-2022 02:36 PM - edited 11-11-2022 02:37 PM
You might consider picking a reloadable Visa card from your local Supermarket or gas station.
11-11-2022 02:34 PM
Thanks but I am in the WestCoast. Too far to pick one up.
11-11-2022 02:33 PM
@Sasan223 sorry, you mentioned that u don't have debt card. it is my mistake.
11-11-2022 02:32 PM
I bought it at Centre mobile plus at 6966 St-jacques Montreal
11-11-2022 02:32 PM
@Sasan223 sometimes it needs to take up 24 hrs to verify the voucher. You can try using your debt card to pay the fund. I hope it can help.
11-11-2022 02:29 PM - edited 11-11-2022 02:30 PM
I am surprised that a retailer sold you a SIM. It can only be purchased from PM or Amazon.
You will need a CC to activate your SIM. It will be difficult to active a SIM with your $40 voucher.
Try contacting a CS_Agent to see if they will activate the SIM with a voucher.
Where did you purchase the SIM?
11-11-2022 02:18 PM - edited 11-11-2022 02:18 PM
@Sasan223 there is no more activation by voucher
but no worry, there are 2 ways to do this:
1. you can use a CC to activative first and use the voucher for future renewal
2. you can open ticket with PM and ask them to arrange to manually activate your sim card and create you a My Account in suspended status. Once you got the login info from PM support back, you can login and apply the voucher to finalize the activation
to open ticket with PM support fir this manaul activation, message them:
