Activation account
Finusa
Hi, I did my payment, but I cant phone to anyone,what to do ? But my account status is active because my current plan cycle is due September,6. What to do next for to make calls? Thanks  for letting me know
@Finusa wrote:
Thanks for reply. But I did all this. I cant phone anyone anywhere yet
Hi @Finusa - are you able to confirm the below...
"\What about incoming calls, texts in/out and data. Do those work?
Can you try you sim into another phone to see if outgoing calls? "
HI @Finusa   are you on the $15 limited minute plan?  If you are , you might have used up the 100 outbound minutes.   Loading the Plan amount early would not renew you plan early.  In your case,   you will need to buy extra add-on for $5.
And alternate way is to use VoIP app like Fongo, you can make regular phone calls using the apps when you have Wifi or Mobile Data.  This could be a free workaround until Sep 6 renewal
Dial 611 from your cell phone...that'll tell you if plan is still Active and when your plan is set to renew.
Finusa
@Finusa - your plan is Active and due to renew on September 6th, okay.
How long have you not been able to call anyone?
Can you try you sim into another phone to see if outgoing calls.
Try 1 or more of the below:
  • restart your phone
  • toggle into and out of airplane mode
  • perform a Reset of the device's Network Settings
  • move your sim card to another phone to see if services works
  • manually select the 3G / WCDMA ONLY network in your Mobile Connections area in your settings (temporarily) to see if calling improves
If issues persist, submit a ticket to CSA for assistance.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them found here:
