Activation Issue from Koodo
JMeyer
I ported two numbers from Koodo.  First one went flawless.  Second one will not connect to Public Mobile Network.  I did reply Yes to the port authorization from Koodo.  Help
Mustafar
How is Koodo?
Metal1967
@JMeyer  good things come to those who wait.. you’ll like PM
JMeyer
Working now after send PM thanks.
JMeyer
Both accounts were active.  Both lines where on same Koodo account. Can still login to Koodo for 90 days.  Sent a private message.  I guess I have to wait.
Meow
Were both accounts (second set) active at the time of porting?
Can you still log in to failed Koodo account?
Since both companies are under the same umbrella you can ask agent for asssitance.
- Send a private message to the CSA - agent by clicking Here
Hi @JMeyer if it does not even connect,  it is sim setup problem
put that sim into another phone and check if it works
Still not work, then open ticket with CS agent at : https://publicmobile.ca/chatbot.
First type Contact,
from the list of , choose "Other"
