06-15-2018 10:45 PM - edited 01-04-2022 06:11 PM
Tried to active sim card. It showed message - Activation Failed.
Sent message to moderators a few hours ago - No responce.
Tried to activate again - Invalid Sim number and email already in use.
Tried to log-in - doesnt let me.
So what the next step? Anyone can help me?
Joining Public
06-23-2018 12:44 PM
just curious, what exactly doesn't work?
06-23-2018 11:33 AM
whats up with the customer service ... my god !!!!!!
im having a bad experience!!!!!
06-23-2018 11:30 AM
I need help also no service since I reactive my account.
.... whats worng with there the service
I will not blame , but I need answer
I paid already!!!!!
06-16-2018 09:22 AM - edited 06-16-2018 09:22 AM
Well, tried to activate this morning. Now it looks like everything is fine. Thanks to everybdy.
06-15-2018 11:55 PM
@will13am wrote:@alexs20, when your get invalid SIM card, email already in use error, that means the activation failed but there was enough progress that you cannot try it again on your own. The only way forward is to contact the moderator team for help.
Are you sure when I registered a couple months ago and it froze on the last step I was able to wait an hour or 2 then I stopped get the sim error and was able to register
06-15-2018 11:50 PM
06-15-2018 11:50 PM - edited 06-15-2018 11:51 PM
@alexs20 wait a few hours before trying the activation again. Sometimes when the activation doesn't go through it still holds the sim number for an hour or 2. After waiting try the activation process again. As mentioned above clear history/cashe (I find using Google Chrome incognito mode works the best for activation) before attempting another activation.
If it still doesn't work you will just have to wait patiently for the mods response as mentioned above
06-15-2018 10:58 PM - edited 06-15-2018 10:59 PM
Did you try putting the SIM in your phone to see if it works? Maybe it already activated.
06-15-2018 10:56 PM
Tried, tried everything, it simply doesnt work. After the "email in use" message even tred to make a password reset via "Forgot passfor" forms, but then it says that user does not exist. the system's responses are inconsistent and confusing.
06-15-2018 10:48 PM - edited 06-15-2018 10:50 PM
@alexs20 Unfortunately you would have to wait until Moderators_Team respond in the morning.
Try to clear browser's cache, use different browser, use Private / Incognito mode, turn off ad blockers.
Contact Support hours of operation:
Monday - Friday 9AM (EDT) - 9PM (EDT) Saturday - Sunday 9AM (EDT) - 7:30PM (EDT)
You will receive a response within an hour, if you are lucky OR it might take up to 48 hours, if your luck is run out!
