Activating Sim - $50 a month plan not shown?
crreature
Hi!
Just got my sim card and I'm trying to activate it - I want the $50 a month for 6 GB of data as advertised in the plans section, but this is not coming up as an option?!
Any advice?
crreature
Nice! Just the news I wanted to hear 🙂
Guess I'll actually go ahead with buying it now! Smiley LOL
koimr1
@crreature wrote:
Okay awesome, thanks!
Also quick question about the canada-wide add on - it says if you don't use all the minutes you buy in a month they roll over. Do they roll over indefinitely?
Yes - I bought the Canada-wide add-on when I first started at PM and it stayed for ten months. 🙂
And I know you didn't ask this but this does NOT apply to the roaming add-ons - these WILL expire after their duration.
crreature
koimr1
@crreature wrote:
Actually if I "build my own plan" for 30 days, provincial calls, international texts and 4+2GB data that comes out as $52 - is this the same thing as the plan only without the autopay deduction???? I'm confused
Yes, that sounds right - the plan description also has this point:
"8 $50/30 days with a $2 AutoPay reward activated (Reg price $52)"
So the regular price is what you're seeing, you'll be at $50 though if/when you set up Autopay. 🙂
ShawnC13
@crreature wrote:
Hi!
Any advice?
I see the plan as well, I am not sure what would happen if you clicked on the getting stated link
crreature
