Activated 40$ fall promo plan error with data
Ckram82
Hi I am getting a "you are not subscribed to a cellular data service" message.
My plan states I have 12gb over 90 days.
Help please
Mary_M
Retraité / Retired
Retraité / Retired
Hey @Ckram82,
Don't hesitate to let us know if you need assistance 🙂 We would be more than happy to help!
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
X-Files
 Check  your Self-Serve Overview , at My Add-Ons see how many Amount Used.
if It's not over limit then send a private message to a moderator. Good Luck!
Ckram82
@will13am thanks
will13am
I suggest you send a private message to a moderator.  Otherwise, if you are going to use the public forum to communicate, tag a moderator to bring your issue to their attention quicker.  I will tag a moderator for you.
@Shazia_K
