Account
BeverleyKennedy
Primary deceased, secondary # to continue service same account # for AutoPay.
@BeverleyKennedy
Is your topic solved?
If not, more details of your situation may be helpful. Community members are customers like yourself offering troubleshooting advice. We have no access to your account.
BeverleyKennedy
What are the highlighted errors?
hi @BeverleyKennedy
PM system is one account for one phone number.  If you have two numbers with PM, you must have two different account with different account numbers and different login.
you should sort out the account and login with PM support agent and cancel one account if not needed
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
