Account
Cya
How do I find my account number?
2 REPLIES 2
As the main reason to get the Public Mobile account number is to port out, it should be noted that IMEI can be used for number porting.  If you're considering porting out to a different carrier, are there issues with your Public Mobile service that you'd wish to ask about?
HI @Cya
login to My Account or PM app, the account number is on the Profile page of My Account or the Account page on the PM app
if you have trouble logging in, ask PM support to help.  You can submit  ticket by direct message:
