03-15-2024
09:25 PM
03-16-2024
01:38 AM
computergeek541
I attempted to purchase another 15 days of calling, text and data for $30.00.
The response is "cannot process at this time".
I also noticed that my account shows a total of $80.00 for my plan, which is almost double what it actually is.
Please review and correct.
Thank you
Regards,
03-15-2024 09:28 PM
HI @LHM11
re-buying the same US roaming after the first one has expired is a bit troublesome, you need to wait 24 hours
I understand you don't want to wait, so, you will need PM support agent to help to re-buy for you. please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
