08-22-2020 10:50 AM - edited 01-05-2022 03:37 PM
Just attempted to change my plan and top up the account from a very recently expired plan, and now my account is glitched. Charged the incorrect amount for the plan, is now saying that my required top up amount is zero and will not allow me to re activate.
08-22-2020 12:36 PM
Pro Tips: Sometime, SIMon may not let you to create a moderator support ticket.
It is important to give SIMon the correct phrase "plan change not working" for your situation.
08-22-2020 11:11 AM
As you wait for moderator help (usually takes a few hours), some more details may be helpful. Which plan were you originally on? Which plan were you switching to? How much money was taken from your account?
Changing your plan while suspended often messes up the process. You may want to manually load some funds into your account equivalent to what is needed for your new plan. Sometimes just loading the funds will restart your plan. That also will help when moderator gets involved if the funds are available for them to fix your account.
08-22-2020 10:55 AM
@Jkeenz your plan may be stuck mid change. Contact the moderators, explain your situation and ask them to reverse the wrong renewal and switch your plan for you. There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-22-2020 10:53 AM
@Jkeenz wrote:Just attempted to change my plan and top up the account from a very recently expired plan, and now my account is glitched. Charged the incorrect amount for the plan, is now saying that my required top up amount is zero and will not allow me to re activate.
@Jkeenz hi you may need to contact a moderator for assistance to contact a moderator click on the ? Bottom right hand corner Ask Simon to speak to a human this will help create a ticket to speak to a moderator mention account issues check the envelope top right corner for a reply response time is 2 to 48 hours
