@TLGuan try using Incognito mode to login
Also, after the enter the 6 digits, wait for 5 seconds and do not click anything, it might login autoamtically
If that still not working, then PM supports are your friends and they will sort it out for you. Please open ticket with them:
1. For faster response (2-48 hours), use this direct link: https://publicmobile.ca/chatbot.
**Start with typing "Forgot Login Information", click "Contact Us", click "Click here to submit a ticket".
2. Or Private message to the CS Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
