04-24-2025 11:54 AM
04-24-2025 05:08 PM
@Giseoksong wrote:Hello,
I'm looking for my account number.
For porting out a phone number to another carrier, the account number isn't actually required. While it's advisable to use the account number when possible, using IMEI also works.
04-24-2025 11:56 AM
Hello @Giseoksong
Your account number can be found here when logging into your account.
https://myaccount.publicmobile.ca/en/account/my-profile
It's under Account Info on the 3rd line. Just press the eye or paper to copy it.
04-24-2025 11:56 AM
hi @Giseoksong
can you login My Account? you can find the number on the Profile page of My Account using the browser, or you can login the PM app and get the number from Account page
04-24-2025 11:55 AM - edited 04-24-2025 11:55 AM
Login My Account or App and get the account number from Profile or Account page
But if you cannot login, you can ask PM to give you the number. Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
