Account locked.
fbriere
Like the tittle say, I was trying to reset my password then my account got locked.
It seem to be the place to ask for this, so.
Issue: can't reset my password, account is locked.
Best regards.
Best regards.
@fbriere ,
Suggestions are usually:
  • clear your browser's cache
  • try a different browser
  • open a tab in incognito mode
  • try the Forget your password option
  • try again in 1 hour
But, yes, as @hTideGnow there is some maintenance happening, so maybe keep revisiting to try today.
https://www.publicmobile.ca/en/on/get-help/articles/moderator-hours-of-operation
You need to wait an hour  before trying  again.
If still fail, you will have to check with Mod:
To open a ticket with mod, click on the Bubble or directly at : https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Enter your question in SIMon. Follow the prompts until you reach the Contact Us button,
If you have problems submitting a ticket, you can also send a private message to the moderators (but this can take longer):
