Account credit
GerryMac
doom loop trying to reach an agent
Believe I should be credited for $6 on October points back
Hopefully I get a reply and solve this problem the only thing lacking with public mobile is their customer service flawlessly as far as the technical part of it goes there's absolutely no complaints with the system
2 REPLIES 2
@GerryMac
What are the detail of the $6 credit?Because the minimum credit is $15 when you have 15 points.
SourDude1234
Hi, how are you trying to reach an agent. Use this link so you can directly message an agent
