10-12-2022 01:59 PM
Hello,
Once again I am having the same problem as I did in Dec 2021. I can not access my account using my email and password. I went through this same problem in Dec 2021.
My Account
10-12-2022 02:03 PM
@gbardai Have you tried clearing cache/cookies and using incognito/private mode or another browser to login?
If the password reset didn't help, then you'll need to submit a ticket or send a private message to customer support. Here's couple of links if you need them, try the chatbot first.
chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
10-12-2022 02:01 PM
What are you wanting to do in your account? There are other ways to do some things.
Can you try a different browser or device or use private mode.
