04-03-2021 10:41 PM - edited 01-06-2022 02:27 AM
I saw from another message that someone else had the same problem. My account deactivated from a missed payment even though I have autopay. According to the other message, there was an autopay system failure yesterday. My question is do I have to manually pay now, or will it automatically pay by itself and ill get my account back. Because when I log in to my account, there's a message saying I missed my payment, but to ignore it if I have autopay enabled.
04-04-2021 07:33 PM
How much is your plan? You have to pay the full plan amount to reactivate your service. If your balance is more than your plan amount ( not counting any rewards) then click on reactivate. If your account status changes to active log out and reboot.
If nothing happens the go to the usage or plans page. Click on lost/stolen. Suspend your service. Log out/in. Resume your service. Is it showing active? If so log out and reboot.
** Make sure you have enough to cover your plan not your amount owing.
04-04-2021 07:09 PM
So I added 25 dollars to.phone just to get by for a week
It says I have 35 dollars but it's not activated
04-04-2021 12:21 AM
@Sadaqat I should have mentioned...if your services are working and you see an "expired" or "suspended" message on your self serve account, then ignore those messages. It is just normal renewal process.
But if you have no sevices, then Yes, your autopay likely failed and you will need to make a manual payment.
04-03-2021 10:45 PM
@Sadaqat wrote:I saw from another message that someone else had the same problem. My account deactivated from a missed payment even though I have autopay. According to the other message, there was an autopay system failure yesterday. My question is do I have to manually pay now, or will it automatically pay by itself and ill get my account back. Because when I log in to my account, there's a message saying I missed my payment, but to ignore it if I have autopay enabled.
@Sadaqat make a payment by calling 611 on your device if credit card is registered to your account.
04-03-2021 10:43 PM
Yes, you need to make a manual payment to get your service working again if it has stopped working.
