07-09-2020 03:05 PM - edited 01-05-2022 12:24 PM
Hi
I currently have the 8 Gig monthly plan. My roommate is also on Public Mobile and wanted to upgrade her current plan from 2 Gig to the 8 , like mine. She paid $50 for the 8 - or least she thought she did - and assumed it was upgraded , but she discovered that she only renewed her account for another month rather than getting the upgrade. Is there anything she can do to get the 8 gig plan without having to pay another $50?
07-09-2020 03:09 PM
07-09-2020 03:09 PM
07-09-2020 03:09 PM
@bb6640 there are no refunds here, however of your roomate was to contact the moderators, explain what happened, that a mistake was made and ask them nicely to switch it for her. It may happen.
There are 2 ways to contact the Moderator Team:
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
07-09-2020 03:12 PM - edited 07-09-2020 03:14 PM
@bb6640 can you check her "available funds" balance and see if there is an amount showing? also, did she choose "change plan immediately" of " change on next renewal date"?
