Accessing voicemail
Narik
What number do I call to get to my voicemail? I get notifications that I have a voicemail but I can't listen to it.
Most often, this is done by using your cell phone and holding the 1 key. Your phone should then dial a voicemail retrieval number. You could also call using a different phone by calling yourself, but when your voicemail box answers, press the * key and enter your vociemail password.
geopublic
@Narik  Hold down the 1 key on your phone to access your voicemail.
Emeris
You can dial your own mobile number if the default one in your phone settings does not work.
