Access error message
Barneysvan
Electronic help is NOT helpful. Just takes me in circles for hours wasted was not able to get here for a long time either.  The system acknowledges My identity is correct but error message stops access to account.
1 REPLY 1
HI @Barneysvan
if you are seeing the error trying to login, try using Incognito/private/secret mode on your browser.
if same,   please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
