About topping up
Amandaharris38
This new system is asking for me to verify my account but the issue is that the email that is with my account doesn't work anymore how can I change the email cause I need to top up my account
dust2dust
The registered email address is just a login. You only need to remember your password. But if you are suspended then you can't do it. So if you use the other methods of payment and additionally real time payments in some stores then you will reactivate the account and then you can verify yourself using SMS. Then you can login. If you like then you could turn off the 2FA login option. It would still be needed for some other changes in your account.
But yes also as mentioned, you'll need support to change the registered email address
Yummy
Only agent can update your account email.
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
- Send a private message to the CSA - agent by clicking Here
HI @Amandaharris38   You can ask to change your email address for My Account login.  To do so, you need help from PM CS Agent:
To open a ticket with PM CS Agent. at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
First type: "Forgot log in information"
Then Click "Contact Us"
Finally Click "Click here to submit a ticket"
Once ticket is submitted, make sure to check your Community Inbox(top right corner envelope icon) periodically for response from PM's CS Agent
@Amandaharris38  - can you top up by calling 611, if you have a card registered on your account?
OR, you can also look into obtaining a voucher to make a payment through 611,  see here: https://www.publicmobile.ca/en/on/get-help/articles?q=vouchers
Locations to obtain some: https://publicmobile.ca/en/on/payment-voucher
In order to change the email connected to your My Account, you need to ask a CSA to do that for you.
To contact the Public Mobile Customer Support Agent (CSA)_Team, there are two methods to reach them:
1 -  Faster  use this link to: Get Help With SIMon the Public Mobile chatbot
OR
2 – Slower - Use this link to:
Contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
