07-11-2026 09:46 PM
My APN is set to isp.mb.com
i don’t seem to be able to change it to the suggested sp.mb.com
07-11-2026 11:14 PM
The iPhone APN is hidden; what you see is just the “Personal Hotspot” APN.
07-11-2026 10:00 PM
@cp3580 wrote:My APN is set to isp.mb.com
Depending on your phone, you may not be able to change them. Which make and model are you using.
