APN
khoat
do we need to set up a certain APN to use Public Mobile’s Data?
13 REPLIES 13
Normandos
J'ai acheté récemment un cellulaire ulefone note pro 16,. Je ne peux pas utiliser les données mobiles avec celui-ci. Surement a cause du APN non conforme avec Publis Mobile, Pouvez-vous me donner l'APN pertinent pour que ca fonctionne
khoat
card*
khoat
hahahaha
khoat
i think it is, i put my sim cars from my old Iphone XR and it was working fine except for the data. I just fixed it thanks to your replies.
Great find if you got it for a good price. I only miss one thing about the UK.
khoat
Yeah! We got it in the UK, i was living there for a while and there was this great deal.
@khoat wrote:
I just bought an Iphone 14 Pro Max.
HI @khoat
For iPhone , you cannot change much for APN
So, you need to do two things
1. make sure Carrier profile is updated
2. click Reset network settings
VERY nice purchase. I'm jealous. LOL
khoat
Thanks let me try that!
khoat
Chalupa_Batman
Data should work automatically. What issues are you having if any?
HI @khoat
yes, you need correct APN to have data working
But you can start with Reset All networks and usually it is sufficent.
what brands of phone do you have?
