APN settings
puritycontrol
Just joined PM and am trying to change my APN settings on an iPhone 6+
I changed the settings as per http://www.unlockit.co.nz/mobilesettings/settings.php?id=1019 but the following fields keep automatically re-populating after I delete them (I ported from Fido, if that is relevant):
Visual Voicemail APN: sp.koodo.com
MMS APN: sp.koodo.com
MMSC: http://aliasredirect.net/proxy/koodo/mmsc
MMS Proxy: 74.49.0.18:80
Personal Hotspot: sp.koodo.com
Am I doing somethign wrong here?  One thing to note is that data IS working.  For the first 10 min it would only connect via 3G but it literlly just went to LTE 10 seconds ago.  Which means I won't have to ask my second quesiton of why I was only on 3G!
So I leave the above as is?
55 REPLIES 55
sarah
To clarify in this thread, what i wrote in another thread. I am trying to follow these steps, that are outlned in MESSAGE 2 of this thread.
APN Tethering Settings:
Name: Tethered Mobile Internet
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
Authentication type: Not set
APN type: dun
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
When i am in Access Point Names, I am able to follow MESSAGE 1 of this thread (APN) because there are options to input every setting listed there. but as far as MESSAGE 2 (TETHERING APN), I do not really see WHERE I can go to input every setting listed there.
If you look at the steps MESSAGE 2 is telling me to set... i am not setting them, not because i am setting it wrong or dont know how... but i dont see WHERE  i can set them. These steps (that  i have cut and paste here from MESSAGE 2 and placed between 2 rows of stars)... simply... I have to find WHERE to go on the phone to set them.
My phone is samsung gallaxy s3.
Hello,
I googled the following: samsung s3 mms problems.
A quick perusal of the results brought me to a page from forum.androidcentral.com. There were a number of posts about the incompatibility of MMS and the S3, and how it was solved.
I suggest googling the problem until you find a fix.
Best of success!
Hi sarah,
It makes perfect sense to me, but, unfortunately, I'm at a loss to help resolve your situation. The APN settings should enable MMS, but, for some reasons, they don't have the desired result.
All that I can think of at this point, assuming that you entered the correct settings, is an incompatibility with a texting app not native to your phone. Would it possible to uninstall it/them to see if the situation resolves itself?
I'm trying to engage in process of elimination to solve the problem at hand.
Though I have not done so, have you googled your phone to see if it has a problematic history of not supporting MMS even though the service is being provided by the carrier?
sarah
The reason i am trying to fix these settings is to be able to send pictures in txt message. (mms). This isnt working. I have plan E (no data, but unlimited picture texting)..Does this make sense?
Deleted by Martin.
Hi sarah,
If I'm 99% certain about something, I say nothing because posters deserve information that is 100% correct. In your case, I replied to your previous posts, and so it would be rude of me to not respond to the most recent one. At this point, I cannot think of a solution regarding settings.
It may be worth your while to once again enter APN in the search engine, and read the other posts. In so doing, you may find a post dealing not only with what settings you need, but also how to enter them.
Good luck, and cheers back to you!
sarah
yes  i found this page too
http://www.samsung.com/ae/support/skp/faq/435820
but it has no connection to the TETHERING SETTINGS that @makkahn28 is saying to amend (message  2 in this thread), as far as i can tell.
Also i have plan E (zero data), so this Tethering and Mobile Hotspot setting, i am not sure is of any relevance to me.I use the WiFi in my house to have internet on the phone.
cheers!
hi sarah,
My phone charged faster than expected.
Google the following: Galaxy S3 smartphone tethering settings
I just did the above, and I came across an article with a photo of the settings plus text describing tethering and hotspots.
Cheers.
sarah
@makkahn28
Sending pictures in text is not working and so i am following these steps.
Mobile data is ON.
APN is completed
Tethering APN : Not sure where to go on my Samsung Gallaxy S3 to find APN Tethering Settings.
Pls help.
Cyber
@sarah,
Yes, it's MMS Proxy.
The C was a typo error.
sarah
i checked again, maybe this has something to do with it.
in your step it says:
MMSC proxy: 74.49.0.18
in my phone for that step, it says
MMS proxy
(i went ahead and set it to 74.49.0.18 like you said)
but maybe this has something to do with it...
sarah
thank you for giving me the information
i did everything exactly like you said but it still does not work.
I will try it again, and again, to make sure i am following every step (it seems i am!)
if it still does not work i will have to ask again?
Cyber
@sarah,
If you do not have a DATA plan, the data consumed by Facebook, Viber, etc. is useless to monitor.
On a prepaid service, you cannot use a service that you don't pay in advance.
I gave you all the informations to have functional MMS.
sarah
i am not talking about the FREE DATA for MMS, i am saying that when i ENABLED MOBILE DATA, OTHER DATA started to get tabulated (Viber, Android OS, Google Play Services, Messenger, Facebook, Samsung Push Service), and now it says that i have used 32.43KB of data on those things (even tho i was not using any of those apps, i was just testing to see if MMS works).
Do you or anyone know how to get my free unlimited MMS to work?
Cyber
@sarah,
How do you think MMS are sent and received ?
MMS is using the DATA network.
The DATA used to sent/receive MMS are not counted. This is FREE data.
Public Mobile is a prepaid service. You won't have any suprise !
sarah
As an aside, the plan i have is Plan E.
UNLIMITED picture msging but ZERO DATA.
i do not want internet data to start adding on (that i have to pay for) as i try to send a picture (which is free)
Even if i am NOT using internet in any way, it seems if i turn on MOBILE DATA, even for a minute, KBs of data start adding up, despite me actively ignoring all internet related anything.
sarah
indeed i  did select that "internet + MMS"
i did activate mobile data when testing MMS.
I do not have a mobile data limit
Cyber
@sarah,
You need to select "Internet + MMS" for your APN type.
The MMSC link is not a functional external web link.
You need to activate your "Mobile Data" to be able to send/receive MMS.
If configured, try to disable your "Mobile data limit".
sarah
I have an ANDROID. I followed the steps, it does not work.
I have two guesses as to why.
The last step of step 2 is this
APN type: default,supl,mms,dun
On my phone, (samsung gallaxy S3), the APN type options were:
Internet + MMS
Internet
MMS
(i checked the first one)
So, this step is different from your instruction options.
Also, fyi, this step:
though i did input exactly as told, i clicked on this just to see, and it leads to a 404 page not found.
I do not know why it is not working, but these are 2 things i thought to share.
I really need to send pictures in text please help
Cyber
@sarah,
You need to configure your APN settings to be able to send pictures (MMS) and navigate on internet (DATA). Remeber to turn ON your "Mobile Data".
Android APN step-by-step configuration :
Lithium-OrangeBullet-Jan23-00.jpgStep 1
Android
Settings > More / More Networks / Wireless & Networks > Mobile Networks > Access Point Names > New APN setting (or a plus sign)
Click here for Android APN Screen Shot
Lithium-OrangeBullet-Jan23-00.jpgStep 2
You will need to input the following information :
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMS proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
Lithium-OrangeBullet-Jan23-00.jpgStep 3
Select Save/Done. Select Public Mobile to connect to the Public Mobile network.
sarah
So that i may send pictures in txt?
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Server: Leave blank
MMS port: 80
MCC: 302
MNC: 220
Here's the Set-up guide that Public Mobile forgets to add in the starter guide. This is why ppl have issues with all the data and texting issues, and what needs to be done to better educate ppl on this
APN: isp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMSC: Not set
MMS proxy: Not set
MMS port: Not set
MCC: 302
MNC: 220
APN type: dun
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
makkahn28
APN Settings:
APN: sp.mb.com
Proxy: Not set
Port: Not set
Username: Not set
Password: Not set
Server: Not set
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
