04-03-2019 08:34 PM - edited 01-05-2022 04:09 AM
Hello Community!
I bought a new Umidigi A3Pro through Amazon last week. Unfortunately, when I am trying to use my mobile data, it is not working. There is a default APN settings that cannot be edited. The sim that I have inserted in Umidigi A3Pro was my existing public mobile sim being used in my LG G4. There has been no problem in my LG G4 using the existing sim. Since I have a new unit, I transferred my sim from LG G4 to Umidigi A3Pro, sad to say mobile data is not working.
Is there someone here that has the same problem? What did you do? Please help and thank you in advance.
04-24-2019 09:36 AM
I had the exact same issue. What worked for me is I ordered a Roam Mobility sim card (Amazon $4.95), took my PM sim out, popped the roam one in, was able to manually add PM APN, put my PM SIM back in and Voila!
04-14-2019 05:14 PM
u need to hook the phone up to a pc ss well to do thos
04-14-2019 05:10 PM
walmart woulf not let me in st john..i returned phone to amazon .Itd umidigis software
04-11-2019 08:29 PM
yes agreed i received no such info from moderator other than tske to tevhnician was finap response .Not nice .Ty i hope this will help .If pm knows there is sn issue with umidigi phones not getting data with pm card but is with other sims then it is not umidigi .I have been attempting to resolve this .ty community members
This problem is not isolated to PM.
There's another SIM from Roam Mobility that will apparently allow making the APN. Then there's the rather more complicated app that can open it up too.
04-11-2019 08:19 PM
04-10-2019 06:16 PM
UPDATE:
After reading everyone's insights, I use a Freedom Mobile sim and put it into my Umidigi phone. Added PM's APN setting and saved it.
Removed the Freedom Mobile sim, inserted PM sim and viola, mobile data is working now.
It's just sad to say that PM can't do anything to have the APN settings be edited and we have to do this manually using another provider.
Thank you everyone for your inputs.
04-04-2019 01:15 AM
@bethm0606 wrote:@geopublic, will try your suggestion. Thank you
Hope it solves the problem. Please keep us updated.
04-04-2019 12:53 AM
@bethm0606 wrote:Tried the link that a fellow member sent me, followed the instructions, unfortunately, there are some info that doesn't show up in my screen (like USB debugging).
Will try to buy a different sim and see how it goes. Tnx
In order to see USB Debugging you need to turn on Developer options on your phone. Just click on settings --About -- Build. Just tap on the build number three times
Once Developer options are enabled just access that option and turn on USB debugging.
04-03-2019 10:50 PM
@bethm0606Try enabling developer mode first
go to settings
about phone
click on build number a bunch of times
then you can go back to settings, system, developer options and find the settings "andriod debugging"
04-03-2019 10:31 PM
04-03-2019 10:28 PM
04-03-2019 09:35 PM - edited 04-03-2019 09:38 PM
@bethm0606 wrote:Hello Community!
Apparently if you insert a Freedom Mobile SIM into your phone it will allow you to add APNs. So if you can get access to one insert it add the PM APN info put in your PM SIM and it should work.
04-03-2019 08:55 PM
@RobertQc
I tried resetting it, manual and automatic network but still cannot edit the APN.
Will try the link that you sent and get back to you whatever the results is. Thank you for your help.
04-03-2019 08:51 PM - edited 04-03-2019 08:54 PM
@bethm0606 Have you tried a network reset, then automatically connecting to whatever network / removing sim card and allowing carrier settings to re-assign?
Is the network operator (public mobile) on automatic, or manual?
You likely have 8/8.1 android. Common problem. If you have 8/8.1 try this https://forum.xda-developers.com/showpost.php?p=75157321&postcount=14
Read through this post too https://productioncommunity.publicmobile.ca/t5/Phones-Hardware/Android-8-1-APN-settings/td-p/241715
