2 hours ago - last edited an hour ago by computergeek541
Hello all, today I activated my Public sim, set it up, and attempted to connect to data on my Android 8.1 device. I realized shortly after that you have to set up an APN on Android phones in order to get proper connection. However after setting up the APN as per the official post when trying to save the APN I get hit with this error every time:
After this I tried fiddling around with various settings including this set of settings, but the same error always came up. If anybody has an idea of how to fix this please let me know ASAP!
an hour ago
an hour ago - last edited an hour ago
@4199 wrote:Typing the APN in all caps did not work unfortunately
@4199 , this is the latest help article for APN settings.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
2 hours ago
2 hours ago - last edited 2 hours ago
@4199 You should be able to update the APN yourself . You might need to in caps APN SP.MB.COM . But if you can’t use the link provided below
2 hours ago
Yes I meant public, sorry for the typo
2 hours ago
@4199 You activated on freedom SIM ? This is public mobile . Or did you mean activated public mobile sim ? If freedom you need contact them . But if public here’s link for support
