ANY APP FOR CHECK DATA USE
09-24-2017 12:37 PM - edited 01-05-2022 03:18 AM
I have iphone and I want to know if any one know for app for account information
Service
12-04-2017 06:43 AM
That's why you check when your next payment date is and adjust accordingly. It's not perfect, but still a pretty good approximation.
09-28-2017 11:10 AM
@zoomzoom87 yes. The only "issue" is that it doesn't deal well with the 30 and 90 day plan lengths available at PM.
09-26-2017 11:56 PM
Android built in mobile data viewer is pretty accurate. I just give myself a warning at 3.5 gb for the month. Pretty accurate for the most part.
09-26-2017 06:40 PM
@Grampa no problem. More info on Data Witness can be found here if you are curious.
09-26-2017 06:03 PM
Thank you! I read mixed reviews of the other data tracker recommended in this thread, so I did not want to take a chance on it. But I just installed Data Witness on my wife's phone to keep track of her 90 day plan. No permissions requested! Simple, easy to use app and well worth with the $1 price.
09-26-2017 03:44 PM
I would advise anyone using My Data Manager to read their privacy policy and see if there's anything that concerns you.
I prefer @IWIK's Data Witness personally, but it's only available for Android. But you may want to look for other alternatives on iPhone, preferably one that only runs locally and does not send your usage data over the internet and share it with other parties. But maybe that's just me.
09-26-2017 10:57 AM
Another vote for My Data Manager, you can go into "My Alarms" and set custom data thresholds so you get alerted when you reach them. I have mine set at 1 and 2GB at the beginning of the 12GB period, ie; I know I shouldn't be hitting 2GB before 1/2 the month is over.
On iOS, if you also go into Settings > Cellular > Use Cellular Data For, you can see which apps are using data and how much. Also reset it at the beginning of the data period. Common culprits include anything that play video: YouTube, Facebook, Safari, Flipboard etc. You can either modify your habits or also temporarily turn them off so they're not using data, just wifi.
09-25-2017 12:35 PM
@mimmo wrote:I use mydatamanger and it is awsome. it does 90 day terms, forcasts usage and adjusts your daily limit based on data used /available.
+1
09-25-2017 11:46 AM
after i download and install datamanger now show VPN on top screen is ok ?
09-25-2017 11:39 AM
thanks
09-24-2017 02:43 PM
I concur with mimmo. 'My data manager' is what you want.
09-24-2017 01:46 PM
Definitely My Data Manager. I love it.
09-24-2017 01:44 PM
I use this as well on android. I agree this is a great, free app for keeping track of data use. I find it fairly accurate as well comparing it to the public mobile data use (website) .
09-24-2017 12:46 PM
09-24-2017 12:40 PM - edited 09-24-2017 12:46 PM
Public Mobile does not have a mobile app but there are data usage apps.
