7B1 Message after Porting...
Annah88
I signed up for a Public Mobile plan. I ported over my number from another provider, got the text message and responded "yes".  My phone is showing Public Mobile, however everytime I try to make a call I get this message.
"7B1 Your phone is not activated on the network, please call client care for more information."
Is there a number for support?
Norajohnson
Try rebooting your device, resetting your network connections, toggle in airplane mode, on and off, and removing then re-inserting the Sim card in the device.The "7B1" error after a number port typically indicates a network activation issue. It means your phone  monkey type  isn't fully connected to the new network, even though you've ported your number. Troubleshooting steps include restarting your phone, checking Airplane mode, verifying carrier settings and iOS updates, and potentially resetting network settings. If the issue persists, contacting your carrier for support is recommended.
@Annah88
Try resetting the Network setting on your phone then reboot the phone and see if that works.
hairbag1
@Annah88
use this link to message Customer Support...they're closed tonight but message 'em tonight and they'll respond in am...
watch that little envelop icon on top right side of page will be highlighted when they respond.
