09-18-2022 11:02 AM
It has been 2 days since I paid for a pre paid plan. I am unable to get incoming calls. When someone calls my number, I get a 5um1 error. How do I get a refund?
Service
09-18-2022 11:48 AM
yeah, I already submitted a ticket. This is so complicated, this whole system sucks. probably last month I am using this service.
09-18-2022 11:32 AM
@whocares3 wrote:yes I changed my plan for that payment
HI @whocares3 there has been some problem with plan change on renewal on the last couple days. Maybe that affected you as well.
PM CS agents have fixed the issue for those who opened ticket with them. Please open your ticket with them:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
09-18-2022 11:29 AM
09-18-2022 11:28 AM
renewed 2 days ago,
status is active
I can make outbound calls, data is not working, incoming calls don't work.
I rebooted my phone , it is an android.
09-18-2022 11:25 AM
@whocares3 , this code is usually associated with a line that is not properly set up? Before seeking a refund, consider asking a CSA to correct the issue. Either way you are going to be in touch with the same people. Anyway, click on the chatbot link at the bottom of the web page and initiate a support ticket.
09-18-2022 11:10 AM
HI @whocares3
You joined 2 days ago? or you joined long time and just renewed 2 days ago?
If you login to My Account, is it showing Active for your account status?
Can you make outbound calls?
Is data working?
did you try reboot your phone? did you try to reseat your sim card?
What kind of phone you have? iPhone? Android? make and model?
09-18-2022 11:03 AM
Did you possibly change your plan for that payment? Or did you just sign up and tried to transfer your number in?
