08-28-2023 09:47 PM
Subscribe yesterday to 5g plan and 5g is not showing as an option on my iphone11. Only LTE and 3g. Can someone please help me? Thanks
Service
08-28-2023 10:48 PM - edited 08-28-2023 10:56 PM
@IceRooster wrote:My mistake mine is an iphone12 ios 16.3
@IceRooster , my iPhone is updated to the latest iOS which is 16.6 !
08-28-2023 10:13 PM
@IceRooster @ wrote:No i don’t see the 5g option and yes I’m incrhe 5g coverage area. My wife is also with PM and 5g is working on her phone.
As softech mentioned, iOS 16.6 is the latest. Have you tried checking for an update again?
08-28-2023 10:11 PM
Because iphone only supports 5g network since iphone 12 and onwards. There's no way for iphone 11 to support 5g network as it's a hardware compatibility.
You will be able to have access to 5g network once you used it on a compatible devices.
08-28-2023 10:10 PM - edited 08-28-2023 10:19 PM
@IceRooster iohone 11 is not 5G compatible . Just iPhone 12 and up are .
Adding sorry missed that you actually have iPhone 12 so it should work . I had similar issue today with Samsung s20 5G works with Telus sim gets 5G but not with public mobile sim check it out @IceRooster
https://productioncommunity.publicmobile.ca/t5/Get-Support/Samsung-s20-5G/td-p/1043088
08-28-2023 10:02 PM
08-28-2023 09:59 PM
I think someone earlier today updated to 16.6 or 16.4 and the 5G options there
and remember to update Carrier Profile as well
08-28-2023 09:59 PM
@IceRooster Do you see the 5G option in your Settings > Cellular > Voice and Data options? If yes, set it to 5G and see if works. Another thing to confirm is if you are in the 5G coverage. You can review the coverage map to see if your area is covered.
08-28-2023 09:57 PM
IOS updated 16.3.1 still no 5g
08-28-2023 09:51 PM
@IceRooster if iPhone 12, then update the iOS first
08-28-2023 09:51 PM
08-28-2023 09:50 PM
08-28-2023 09:49 PM
@IceRooster "the current 5G compatible iPhones are only within the iPhone 12 series and above. To summarize, you'll never be able to use the 5G network on an iPhone 11, 11 Pro, or 11 Pro Max"
08-28-2023 09:48 PM - edited 08-28-2023 09:50 PM
what iOS version you have?
for iPhone, we have couple confirmed that once you updated to the latest iOS, and update the Carrier profile, you will see the 5G option there
update: as @NDesai confirmed, the above trick does not apply to iPhone 11 as iPhone 11 is not 5G compatible 🙂
