03-15-2024 07:49 PM - last edited on 03-16-2024 01:42 AM by computergeek541
I've counted the days and notice that the Bonus data given to me will expire around the start of August.
What I'd like to know is if the 5GB Data Bonus is per month or a total to be used over 150 days?
Also, what's going to happen to the existing bonus data and long-distance credits I have?
03-15-2024 08:56 PM
If you are referring to the More is Merrier bonus data. It will rollover until you use it up.
If you are referring to the recent Legacy to Points Reward switch. You have 150 days to use it up.
03-15-2024 07:51 PM
HI @cory_c
it is one time 5GB and only good for 150 days
it will be used after your regular data for the current cycle are all used up, it will be used before your previous non-expired bonus addon, so no worries.
Your LD addons will not be affected
and yes, you got the bonus 5GB because you will be migrated to the new Points system
03-15-2024 07:51 PM
@cory_c , if you are referring to the bonus data for the legacy rewards customers, it is a one time thing. Once the data expires, that is it.
