07-21-2024
07:15 PM
07-21-2024
07:24 PM
computergeek541
Hello Community,
I recently got the 50GB within Canada and the US Plan with "unlimited Canada-US wide minutes and messaging plus unlimited international text and picture messaging". Can I use my data and call someone while being in the US or it only applies to calling someone and using your data while staying in Canada? In short, can I have all the benefits from this particular plan while going to the US? Would really appreciate some clarity over this!
Thanks!
07-22-2024 08:56 AM
Larrysriver was mistaken, sorry. I don't know how to remove my post.
07-21-2024 10:40 PM
@Urooj_Tirmizi15 LarrysRiver is mistaken and must not have one of the Canada-US plans.
07-21-2024 10:37 PM
07-21-2024 09:27 PM
Oh...The other replies to my post say I should be fine. Are you sure you don't have the Canada only plan? Cause I've read some related posts about it and people have no issues with it unless they have the Canada only plan.
07-21-2024 09:15 PM
I have the same plan and was told to buy the USA data plan if going across the border into the USA $25,
I have done this the last 2 years.
07-21-2024 07:20 PM
@Urooj_Tirmizi15 wrote:Hello Community,
Thanks!
Use that plan while you are in either country to talk / text most any number in either country.
07-21-2024 07:18 PM - edited 07-21-2024 07:20 PM
You can call and text anyone Canada or US number and use data up to 50GB while you are in Canada or US.
once you use all of the 50GB data, you will not be able to use data anymore till your renewal date
