500 mb free data
CB75
I currently pay $40 and get 5 mb . Should I not be gettting the 500 free mb each month on auto renewal?
10 REPLIES 10
CB75
That is what mine says too. Nothing about the 500 extra being offered on new plans
Staliger
@CB75Seems it is a displaying issue. It should show 4.5GB + .5GB, not 5GB. My $25 plan shows 500MB + 500MB at 3G Speed, not 1GB...
@CB75 wrote:
My plan says 5g for $40 butt nothing about an extra 500m
@CB75
I have the same plan and it shows the same thing.  In the overview page, it only shows total of 5GB (doesn't split 4.5 + 0.5)
CB75
Sorry 5gb
CB75
ddeep91
I guess you mean "5GB"
The $40 Plan offers 4.5GB + 500MB with autopay which adds up to  5GB total.
Cheers
Jb456
$40 plan is 4.5 gigs and if you're on auto-pay you get an additional 500 mb bonus per 30 days.
Are you saying you're only getting 5mb of data and nothing else?
will13am
@CB75 , the $40 plan comes with 5GB.
No. It's 4.5GB + .5GB totaling 5GB.
Dunkman
@CB75
The present plan is 4.5 GB + 0.5 GB with autopay.
https://www.publicmobile.ca/en/bc/plans/40for4500MB-3Gspeed
You are getting the correct amount of data for the $40 plan
