500 bonus "Int'l long distance" minutes will be used for "Canada Wide" minutes?
mischt70
 Hi, Do "int'l long distance calling minutes" get used for "Canada Wide" calling minutes if you have no more minutes left?
I'm on the 15$- 100 minute plan.  On occasion I've run out of minutes and bought the 5$ 500 minute "Canada Wide"  top up package.
Last year I recieved the 500 int'l long distance minutes "gift". I have not used any of it.
The next time  I run out of my monthly 100 minutes, would I automatically start using the 500 int'l minutes "gift" for my regular "Canada" calling if I did not buy another 500 minute Canada Wide package, or would my phone just not work for calls?
Thanks!
2 REPLIES 2
mischt70
Thanks, yes I've already done that a couple of times. The Int'l bonus has been sitting there for a year and I just didn't know if it woul be used the same way. The 15$ plan is a good deal with the occasional 5$ top up!
hairbag1
@mischt70
yes they will.
added...
you can also buy a 500 minute Canada wide calling add-on for $5. They get used if you run outta regular plan minutes and if there's any left at renewal, they roll over until you do use 'em up. It's a good investment for those of us with the $15 plan.
