50% discount will be remove if I change plan
Raybberry
Hi,
I;m a new user of Public mobile, I sign up during their 50% discount last Feb. Now I wanna know if ever I change my plan with the 50% discount will be remove?
Thank you,
Raybberry
Yes, it is a great plan,
slusagm
The 50% only applies to the specific plan you chosen and it is not a discount across any plan
So, you will lose it.  And I suggest you not to change plan as this is a great plan with discount, you won't get such a deal anywhere any more
@Raybberry  Yes you will lose  the 50% off if you change your plan
