4G
04-02-2023 12:40 AM
04-02-2023 12:55 AM
@Jim-ford if your see LTE on the status bar on top, then yes, 4G= LTE
if you see3G, then you will need to change your Preferred network or network mode to 4G or automatic
You can confirm you have the 4G / LTE speed by running some speed. test. One good one is to download from https://www.speedtest.net/apps. Please not that each speed test could use as many as 300 Mb of data
04-02-2023 12:44 AM
What makes you think you aren't? Is your set to 3G/HSPA? Or even capable of 4G?
04-02-2023 12:44 AM
@Jim-ford wrote:I have been paying for 4G for months and still don’t have it
4G plans only enable faster data speeds. Can you explain what you mean by "still don't have it"?
