4G plan
naren1
Hello,
I need to change my plan
HALIMACS
@naren1
When logged into self serve, choose the “plans and add on” section to the left, then select from either 3G or 4G suite of available plans.
Use the arrows to toggle between the available plans.
When you find one that suits, select it and be certain to schedule the change on your next renewal. If you do not do this, you will lose whatever is left of your current cycle as immediate plan changes do not provide refunds of what is left on your current cycle.
if you are switching from a 3G to 4G plan, also bear in mind that it may take up to 48 hours for the increased data speeds to be noticeable.
walker1
@naren1
You can change your plan yourself from inside your account.   Just login.
It's best to schedule your plan change for your next renewal date and not change right away.
Meow
Easy to do; log in to your account and click on
then
pick 4G and scroll through plans on right side.
@naren1 @Log into your self serve and go to plan / addon tabs and change 4G plan
