05-26-2019 12:44 PM - edited 01-05-2022 05:05 AM
The public mobile site refers to plans with 4G LTE data, which plans are those?
"4 Plans with 4G LTE data can access maximum LTE download speeds (manufacturer rated at up to 900 Mbps; expected average speeds 12-250 Mbps). Plans with 3G data may reach download speeds of up to 3 Mbps, with the coverage and reliability of the LTE network. "
05-26-2019 01:08 PM
I would think that the main push is for 3G data speeds... taking on competitors like CHATR with the same....
05-26-2019 01:03 PM
@ChewyB wrote:The public mobile site refers to plans with 4G LTE data, which plans are those?
They use to have many more ready made 4G LTE plans but asyouseevthey are pushing deals on 3G speed/ 3mbps plans. You can create your own plan and add LTE speed options however they are often not quite a lot higher and closely equivalent to what Koodo or others can offer etc. I.E. PM. Is pushing the 3G speed plans
05-26-2019 01:00 PM
There is just one $30 plan but you can also build your own plan with 500 MB, 1, 2, 4, or 6 GB options.
05-26-2019 12:51 PM
05-26-2019 12:46 PM
There's just the one $30 ready made plan but you can choose other quantities in the BYOP.
