4G LTE camera
Dustyrds
Hi I just bought 4g LTE security cameras and I'm unsure were I can get data only sim cards that will work with them any pointers
2 REPLIES 2
funpig1
@Dustyrds
Do you have removable Public Mobile sim card in your phone? If so, you could insert it into your 4G LTE camera to test if it will work. If it works, you still need to figure out how much mobile data this device would require each month. Good luck.
@Dustyrds   Public Mobile does not have data only sim cards so you would have to use a phone plan with enough data (if that would work in the device) or try another carrier with data only plans.
