08-13-2019 09:50 PM - edited 01-05-2022 06:24 AM
I purchased the 400 mins a few months ago and you have taken 98 mins off as of the 13th Aug. I have not used the 50 min per month on my plan. I have no data plan.
Why is there a deduction off the 400 ?
08-13-2019 10:08 PM - edited 08-14-2019 12:11 AM
@Wisbeach1 wrote:I purchased the 400 mins a few months ago and you have taken 98 mins off as of the 13th Aug. I have not used the 50 min per month on my plan. I have no data plan.
@Wisbeach1 Best to check your usage history logs. With your plan incoming calls also use minutes. If you still feel that you were incorrectly charged then ask PM to investigate.
To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
Moderators are available: M-F from 8 AM to midnight Eastern time and S-S from 8 AM to 10 PM Eastern time.
Note: Moderator Hours are subject to change, but you can always find the current times here
08-13-2019 09:58 PM
The 50 minutes in your $10 plan is Canada wide minutes.
THe 400 minutes are for calling Canada, US and oversea numbers.
If you Canada number, it should use your 50 plan minutes first.
If you call US and oversea, it will use your add-on minutes.
08-13-2019 09:54 PM
Is it possible that you called long distance out of country to one of the other 16 countries on the long distance list of countries?
Your minutes from regular plan only covers Canada wide minutes.
08-13-2019 09:53 PM
400 minutes are for international calling as well, did you make any calls to other countries? Plan minutes are for calling in Canada only.
