04-24-2019 07:43 PM - edited 01-05-2022 04:35 AM
How long does it take for the 3G throttling to kick in on the $50 8.5gb 3G plan that I signed up for yesterday?
Joining Public
07-05-2019 03:56 PM
@Nathan08 wrote:My wife and I both have Galaxy S7 phones and were with Virgin Mobile. Where I am at, we get LTE speeds with Virgin. To compare Public Mobile's speeds to Virgin's speeds, I switched my phone to Public Mobile and did a speed test. My wife also did a speed test with Virgin (same app same style phone). I found the speeds were cut by 50% (both upload and download speeds.). I was still able to watch Netflix and Youtube, check e-mail, browse picture-heavy sites... no problem.
The actual percentage of difference can vary greatly depending on the speed of the other carrier's connection. For me, speed loss can be from 90 to 99% speed loss on a Public Mobile "3g" plan, but that's because with an LTE plan, I've occassionally been able to get download speeds around 300Mbps.
07-05-2019 07:14 AM
05-03-2019 11:47 AM
@mynewhome wrote:I don't see a 3g only option when searching available networks, does this vary based on geographical location? I only see public mobile lte and wcdma options.
There are several different terminologies. In your case that WCDMA = 3G.
05-03-2019 11:46 AM
04-24-2019 10:05 PM
Yea i agree
04-24-2019 10:04 PM
@coolvehiclefan wrote:Yea i wont be running the speedtest app til I'm actually throttled ive ran it once and used a bit over 100mb
That app can serve a purpose, but don't do it unless you fully know what you're getting into. Unfortunately, I know people do get curious and don't want to feel as if they got ripped off on a speed, so they end up doing some testing. I'm not going to say that I haven't use this app as I have, but when you think about it, this really just wastes data that you could have otherwise used on something else,
04-24-2019 10:00 PM
04-24-2019 09:58 PM
@coolvehiclefan , I would say that no matter how fun it may seem to run that popular speedtest.net app and to try to compare to other carriers and network locations, I would suggest not doing that while you are in your first few days. That app can use a lot of data in one test, especially while your full LTE speed is still enabled.
I don't know the maximum LTE speed that your device can support, but we've seen some results using up 0.5 to about 1.0GB in one try. Some customers likely used up their entire data alotment running this app.
04-24-2019 07:50 PM
Awesome thanks for the help!
04-24-2019 07:49 PM
Great thanks!
04-24-2019 07:49 PM
LTE is normally faster than 3G but PM throttles it to 3MB/sec. 3G is not thottled so it's around 15MB/sec.
04-24-2019 07:48 PM
i think it is 48-72 hours.
