$34 plan
hzhang12
Can I call from US? Or I can only use data in US?
Thanks
hairbag1
@hzhang12
BTW...to call someone while you're IN US...make sure you have a VoLTE enabled cellphone that's on the Public Mobile whitelist of VoLTE enabled cellphones...(not all VolTE enabled are on that list).  The link includes the phones that are ...
https://www.publicmobile.ca/en/bc/get-help/articles/volte
Do you have a plan that was advertised as a Canada-US plan?  Canada-US plans can be used while you're in either country.
