06-17-2022
12:08 PM
06-17-2022
05:27 PM
computergeek541
I saw this promo, just wondering if I have the same promo applied to my account currently? I thought I would be only offered an extra 2GB but not monthly. Can anyone confirm this?
This is the promo:
This is a promo applied to my account:
Once I have used my 2GB does this mean I won't have anymore or will it refresh?
06-17-2022 12:55 PM
Good point, If you decide to go with a 40 or 50 plan etc, I think you should be able to keep the extra 2GB as well or t least that is how I read the T & Cs, but as soon as you go 25 or below, it will be gone forever.
06-17-2022 12:17 PM
Don't change your plan to below $35. You should be able to stay at and above $35.
06-17-2022 12:15 PM
Awesome Thank you!
06-17-2022 12:10 PM - edited 06-17-2022 12:11 PM
HI @banhmami so, this is a screenshot from your My Account? If that is , then the Unlimited under Current Plan Cycle means it is a reoccurring promotion, you can get a new 2GB every cycle, as long as you don't make any plan change
